Technical
Chassis & Suspension Forum
Control Arms
Topic: Control Arms (Read 3604 times)
kafer_kid86
Control Arms
March 05, 2007, 12:26:11 PM »
ok so i installed a new upper left control arm and the bolt comes through way to much
and my old control arm has this spacer type deal do i have to put one on my new arm so it doesnt hit any more?
Jeff Pedersen
\"the other jeff pedersen\"
Hansk
Control Arms
March 05, 2007, 01:41:37 PM »
Yup , you need to pull those camber adjusters off the old ball joint or pick up new ones or better yet get the special ones with even more adjusting range for lowered cars.
kafer_kid86
Control Arms
March 05, 2007, 02:38:15 PM »
can i install it myself or do i need a shop to press them on?
Jeff Pedersen
dannyboy
Control Arms
March 05, 2007, 04:46:21 PM »
they can be a bitch to get off, but once you go to reasemble you just slide em on and bolt it together
Trevor P
Control Arms
March 05, 2007, 10:03:23 PM »
Use a 3 jaw puller to pop them off. Then just slide them onto your new balljoint, and cinch them into the spindle. Tightening the nut will pull them onto the taper.
Technical
Control Arms
