Author Topic: Advice/know How  (Read 1485 times)
Offline stan62vw
Advice/know How
« on: March 04, 2007, 10:19:52 AM »
Hey all you air heads, looking for advise  on lowered spindle install on king link set up got the passenger side all set up .First question are you supose to bend the brass/copper washer between the two bolts on the hub to lock or just stays as is.Secound question when i went to go to install drivers side the bolts on hub they won't go on  the spindles are brand new from C B Preformance  am i over looking something  i feel as if i should not have to tap and dye something brand new  any input would be great :rockon:
Advice/know How
« Reply #1 on: March 04, 2007, 01:50:13 PM »
bend that washer. there should be 2 tangs on it....bend one tang back and away from you over the inner nut and the other tang toward you over the outer nut.
first, thoroughly inspect the threads on the nut and on the spindle to make sure that they are not damaged. the spindle on the drivers side is a left hand thread....so lefty tighty-righty loosey (left to tighten-right to loosen). if that doesnt work, use the nuts on the passengers side spindle (the ones that fit) on the drivers spindle and see if that works.
good luck. B)
« Last Edit: March 04, 2007, 01:52:44 PM by silas »
Offline stan62vw
Advice/know How
« Reply #2 on: March 04, 2007, 02:33:09 PM »
thankyou Silas i thought you had to bend those washers  i will go out and try reverse thread  and mix nuts around :rockon:
Advice/know How
« Reply #3 on: March 06, 2007, 08:21:12 PM »
how did it go stan? any luck?
Offline stan62vw
Advice/know How
« Reply #4 on: March 06, 2007, 10:04:41 PM »
Hey there Silas, your advice  :rockon: I had to take nuts off passenger side put on drivers side  Finished today looks so sweet  got to adjust brakes and  bleed emm  So  happy with  results  thank you for the heads up  on those nuts  another add on done time to start thinkin of another one :rockon:
