Technical
Engine Tech Forum
Oil Deep Sump
Topic: Oil Deep Sump (Read 4938 times)
Skidd
Oil Deep Sump
February 27, 2007, 10:49:39 PM »
The pick up tube, how far off the bottom of the sump should it be or does it madder? Should I run a oil strainer, I am going to run a remote filter?
Geoff
Oil Deep Sump
February 28, 2007, 07:59:19 AM »
aprox 1/2\" from the drain plate
AlanU
Oil Deep Sump
February 28, 2007, 08:15:13 AM »
I run an oil strainer with my 3.5qt sump. You may find that a berg sump will have the proper length pickup tube extension and Empi is shy and too short.
Its a good idea to use an aftermarket big screened strainer so it doesn't impede flow yet catch crap so you dont break you oil pump drive. I've been there done that. Its very common to see the sump nuts loosening off due to vibration.
If your buying an empi sump get a flash light and look inside the sump to see that there isn't left over sand casting. Mine had a big chunk in the corners.
Alan
http://members.shaw.ca/acvw/index.htm
James Buchan
Oil Deep Sump
February 28, 2007, 09:35:44 AM »
Another good practice is to braze the pickup on instead of relying on a cheap hose clamp.
Skidd
Oil Deep Sump
February 28, 2007, 10:10:47 AM »
Thanks for the help.
Skidd
Oil Deep Sump
March 03, 2007, 11:26:57 PM »
Where could I get a aftermarket big screened strainer?
AlanU
Oil Deep Sump
March 04, 2007, 09:02:35 AM »
They are all crappy and big now. The OE VW ones were the super fine mesh ones and those are virtually \"unobtainium\" so just by any crap quality one.
Thats gonna keep sump nuts from getting sucked in the oil pump.
Loctite those nuts in or you'll do what alot of people do..... snap the oil pump drive from sucking in a nut. Even a Gene berg pickup tube magnet wont save your ass.
Alan
Technical
Engine Tech Forum
Oil Deep Sump
