Hi name is Gary.
His home number is 604-599-9477
Here is the info:
Transmission is IRS with a low gear set inside. This car has steering brakes, bikini top, tow bar , balanced crank in a 1910 cc engine with a lightened flywheel, HD clutch, speed shifter, VDO guages, tach, nice wheels and tires, adjustable seats, four point harnesses, fuel shut-off, fuel pressure regulator, bosch 009 distributor, skid pan. I can't remember all the info in the add but there is so many little things that have been done to it to make it special.
Please respond to gamika@shaw.ca reference dune buggy.
I almost did it.
Hope that helps.
