Author Topic: My House Smells Like Gas!  (Read 1660 times)
Offline KOOL-AID MAN
« on: February 20, 2007, 09:28:42 PM »
Hey i was just wondering is it normal for a beetle to smell like gas? I never parked one inside a garage till now, and you can smell the gas in the laundry room, and almost in the kitchen. I checked all the gas hoses and tightened all the connections, could this smell be comming from the tanks ventilation hose maybe?.
« Reply #1 on: February 20, 2007, 09:33:07 PM »
Only if it has a full to the top tank or the gas caps off.
How's the line in the tunnel ?? Look in the morning for wet spots.
Any pilot lights in there ?  :!:  :!:
« Reply #2 on: February 20, 2007, 09:38:21 PM »
nope pilot light is in the basement, I do have a pretty full tank of gas, but the cap is on good.... hmmmm I'm pretty sure its not leaking gas out of the line in the tunnel, its always dry under the car and my car doesn't rush through the gas.
« Reply #3 on: February 20, 2007, 10:15:44 PM »
Mine was leaking from the bottom of the tank, check under the car for small puddle stains that would possibly evaporated gas, but I suggest you leave the car outside until you find it.
« Reply #4 on: February 20, 2007, 11:05:39 PM »
Well i just re inspected a couple things, It's definetly comming from the engine compartment, I jacked the car up and checked everything at the front, it all seems good, not much smell there. Then at the back its very gassy smelling by the carb, i checked the electric cut off, pulled it out turned the key on and grounded it, it sucked in so thats gotta be good.... Any other ideas? all the gas lines are brand new too.
« Reply #5 on: February 20, 2007, 11:29:25 PM »
well it could be anywhere, sometimes just runing your hands along the fuel lines until you hit a wet spot  :blink:  you could have a hose with a soft spot or missing a clamp, or just flooded, single carb?
« Reply #6 on: February 21, 2007, 05:41:39 PM »
hmmmmm, i'll have to check for a wet spot i guess then  :lol:
« Reply #7 on: February 23, 2007, 12:10:20 AM »
do yourself a favour and just replace all the fuel hose... it probably needs it anyhow, is it a stock fuel pump? or electric. how are the throttle shafts on the carb?ive found with old worn out carbs they leak there. also check the accel pump diaphram, sometimes they leak aswell.
« Reply #8 on: February 24, 2007, 04:24:31 PM »
Yessss, i found the problem, It got a lot worse. It was the accelerator pump diaphram! thanks danny!
