Author Topic: Posting A Pic %^&$  (Read 2292 times)
Offline Schvengy
Posting A Pic %^&$
« on: February 06, 2007, 06:41:08 PM »
I have been following the intructuions on the forum but to no luck !!!!!!!!!!!!!!!!!!!
hosted them but can't figure out ....wife not home lol
Offline Schvengy
Posting A Pic %^&$
« Reply #1 on: February 06, 2007, 06:46:10 PM »
if you can help ---------250-764-9846      :rockon:
Posting A Pic %^&$
« Reply #2 on: February 06, 2007, 07:09:43 PM »
get the properties or address from the hosted pic
and add this to the front of it [IMG]  then add this behind it [/IM]
add another G just like the first IMG i did to the second one i just tried to put it exactly how it should be and it thinks i'm linking a pic and it won't work
that should do it for you
« Last Edit: February 06, 2007, 07:10:18 PM by Russ »
Offline Schvengy
Posting A Pic %^&$
« Reply #3 on: February 06, 2007, 07:20:20 PM »
when i go to add and click on img it does not do anything
Offline Schvengy
Posting A Pic %^&$
« Reply #4 on: February 06, 2007, 07:32:45 PM »
Thanks for the help................. F*%K it!!!!!!!!!!!!!!!1
Offline Chris W
  • Portland Oregon
Posting A Pic %^&$
« Reply #5 on: February 06, 2007, 07:37:11 PM »
Are you using photbucket?
The IMG button has never worked for me on this forum. All you need to do after you copy the address of the picture and paste is on here is make it look just like this.... (img)address of the picture(/img) replace the () with [].
Posting A Pic %^&$
« Reply #6 on: February 06, 2007, 07:59:54 PM »
roger that...
right click on the image,
select properties,
copy address or (URL),
paste,
put this after your pasted address
practice with this...
the img button on this forum never works for me either...so i just do it manually from the keyboard.
« Last Edit: February 06, 2007, 08:00:28 PM by silas »
Posting A Pic %^&$
« Reply #7 on: February 06, 2007, 11:16:03 PM »
Same here.  The status bar just says \"Error on Page\" when I hit the IMG button.  Manual pic post:
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
Posting A Pic %^&$
« Reply #8 on: February 07, 2007, 08:50:42 AM »
The IMG tag issue came up when spell check was added. The two bits of code just don't work together. At the time, Geoff elected not to have me spend time trying to fix it.
« Last Edit: February 07, 2007, 08:51:10 AM by jason_hamilton »
Jason Hamilton
Offline Schvengy
Posting A Pic %^&$
« Reply #9 on: February 07, 2007, 02:32:11 PM »
With help from u's i figured it out ...Thanks :rockon:
