Author Topic: Powder Coating?  (Read 4718 times)
Offline 72vwtype2
  • Phil
Powder Coating?
« on: February 03, 2007, 04:39:48 PM »
I have seen a lot of ASF members post pictures of there newly powder coated pans, engine tin, etc... They look awesome, appear to be highly durable and most that I have seen extremely glossy. Correct me if I am wrong but the original pan or engine tin would never have come out that glossy. So as I get closer to needing this service, my question is can you get different degrees of \"glossyness\" in order to try to relicate a more original look? Like a semi-gloss?
Thanks.
1972 Kombi
1964 Vespa 150
Powder Coating?
« Reply #1 on: February 03, 2007, 05:33:06 PM »
yes, and Russ is the man!
« Last Edit: February 03, 2007, 05:33:14 PM by VWChris »
Powder Coating?
« Reply #2 on: February 03, 2007, 08:13:42 PM »
Any tips on how to touch up scuffs on powdercoating.
Offline G-dog
Powder Coating?
« Reply #3 on: February 03, 2007, 10:24:42 PM »
Use buffing compound ,treat it like paint ,use patience.That's all you need to do
Powder Coating?
« Reply #4 on: February 04, 2007, 12:24:13 AM »
I had Russ do a pan for me in Semi-gloss black, and IMO it looks way better than a full gloss finish.
Powder Coating?
« Reply #5 on: February 04, 2007, 10:48:28 AM »
most colours come in a gloss finish.
although i have black in Matt,satin,semi,gloss and mirror black
so i pretty much cover all the bases satin or semigloss is what i do most of the car parts  in.
it all boils down to personal preference
Offline 72vwtype2
  • Phil
Powder Coating?
« Reply #6 on: February 04, 2007, 01:03:07 PM »
My first need for powder coating will be my bus motor tin and other engine bits. What prep work needs to be done in order to get a proper surface for the powder coating? Should the tin be sandlasted and/or primered?
Thanks.
1972 Kombi
1964 Vespa 150
Offline G-dog
Powder Coating?
« Reply #7 on: February 04, 2007, 01:07:20 PM »
Sand blasted-No primer ,just bare metal Russ does the rest (he's my p/c hero) :wub:
