Author Topic: Case Polishing?  (Read 2583 times)
Offline surgerypending
Case Polishing?
« on: February 03, 2007, 04:14:58 PM »
Well....I have nothing but time on my hands for the next 3-4 weeks and i'm bored to death. I'm limited with things I can do but I think I can sand and polish my new Mag case. What do you guys think....waste of time...magnesium will dull out eventually anyway....only a small part of the case is visable with the shroud on?
Case Polishing?
« Reply #1 on: February 03, 2007, 05:34:19 PM »
answering your own questions.....
Offline G-dog
Case Polishing?
« Reply #2 on: February 03, 2007, 10:07:06 PM »
Paint that bad boy....
Case Polishing?
« Reply #3 on: February 04, 2007, 11:20:56 AM »
Hum...maybe powdercoat....Russ?
Case Polishing?
« Reply #4 on: February 04, 2007, 03:33:26 PM »
The baking temps required for powdercoating are high enough to adversly affect the strength of your case.  IOW, don't do it.  Maybe Russ will tell us the actual temp.
Case Polishing?
« Reply #5 on: February 04, 2007, 03:46:30 PM »
it would be baked at 400 degree's
in all honesty it would require so much taping and masking i'm not sure it would be cost effective.
Case Polishing?
« Reply #6 on: February 04, 2007, 04:01:00 PM »
Taping and masking...i'm real good at that stuff!
Is 400 degrees too much heat? Also would the engine run hotter if it's painted or powdercoated?
Case Polishing?
« Reply #7 on: February 04, 2007, 05:51:58 PM »
all that effort for about 6 sq inches?
Case Polishing?
« Reply #8 on: February 04, 2007, 05:58:02 PM »
I'd do it. Not for effect but for piece of mind...
Case Polishing?
« Reply #9 on: February 04, 2007, 07:53:20 PM »
piece of mind??
Case Polishing?
« Reply #10 on: February 04, 2007, 09:54:04 PM »
According to Uncle Gene, the temp at which you will compromise the strength of the case happens somewhere under 300
Case Polishing?
« Reply #11 on: February 04, 2007, 10:15:19 PM »
I dont see the benefit to powdercoating a case thats made of aluminum or magnesium, its never going to rust, it may corrode a little but nothing that is going to affect my piece of mind.
Case Polishing?
« Reply #12 on: February 04, 2007, 11:28:16 PM »
chrome it!!!
Case Polishing?
« Reply #13 on: February 05, 2007, 06:13:36 AM »
chrome it!!!
Gold Plating?
Case Polishing?
« Reply #14 on: February 05, 2007, 08:19:48 AM »
Gold Plating?
sure!! then it'll match yo grill....now that would be piece of mind.
Case Polishing?
« Reply #15 on: February 05, 2007, 09:36:39 AM »
Ah..thats too funny Silas!
Anyway, i'm not gonna touch the case...it's not worth it....thanks guys!
