Author Topic: '71 Swing Axle Gear Ratios  (Read 7247 times)
Offline 66beetle
« on: January 30, 2004, 02:34:45 PM »
My '66 Bug needs a new tranny. I've been shopping around and have located a '71 Swing Axle unit. Now the research I've done indicates that the gear ratios didn't change from '67 to '72 (which is what I want. My stock '66 unit is a pain on the highway), but the charts I've seen didn't make any distinction between the IRS and Swing Axle units made after '67. Is there a difference in gear ratios with these Swinger units or are they just IRS units with swing axles.  Could this have been from a \"Canadian Standard\" model. I believe they came with 1200 motors. Correct me if I'm wrong, please.
Devin Brown
'66 Beetle
 '12 Beetle
« Reply #1 on: January 31, 2004, 12:47:29 AM »
I'm almost sure I've seen a 71 \"canadian stanard\" with a 1200cc.  Those trans would have a 437 r&p , the same as your 66 has now.  I also once had a 73 \"canadian standard\" that had a 1600cc dp with swingaxle but I believe it would have had a 412 r&p , a little better on the hwy.  Now I have a 75 \"canadian standard\"  with 1600cc fi and IRS trans .   Any way  maybe Bruce could tell us agian if the numbers on the trans can tell you what it should be.
« Reply #2 on: February 02, 2004, 09:09:25 AM »
if you are winding out too much on the highway, you could run a taller rear tire.  195/70 or 205/70 would bring up the rear a lot and not wind out the tranny and motor too high.  here are some charts that might help you out. follow the link
Link- beetle spec tables
stephan
Offline Scratchy
« Reply #3 on: February 02, 2004, 04:58:21 PM »
Thanks Stephan.
I've been looking everywhere for charts like those!
« Reply #4 on: February 03, 2004, 08:59:19 AM »
Thanks Stephan.
no problem. they are VERY handy!
Stephan
