Author Topic: Adjustable Spring Plates  (Read 3495 times)
« on: January 08, 2007, 08:19:15 PM »
i can't find a link at cip for adjustable spring plates,this is for the 55.
anybody help me out?
how hard are they to install? i assume plenty of peolpe have done them
thanks russ
Offline Darren Dilley
« Reply #1 on: January 08, 2007, 08:56:31 PM »
I had Chris at cip order me a set of s.a.w adj spring plates (i don't think they stock them) to make them work.. i needed to clearance the cast part of the pocket that the spring plate sits in... as Lanny  would say pre fit before you powdercoat or chrome   ;)
Offline Klaatu
    • http://www.airspeedparts.com
« Reply #2 on: January 09, 2007, 10:22:49 PM »
Hey Russ, The Sway Away spring plates are definately better quality but at over twice the price of the wang chung brand! I find that if u want full travel without binding that u should test fit and belt sand the round end of the plate (inner and outer) till u get full movement. I put the cheap plates in the Hulk and they have not failed yet so I think u would be safe to go with them. TJ
I can't reach the bottom but I sure bang the sh*t out of the sides....
