Author Topic: Electric Fuel Pump  (Read 4148 times)
Electric Fuel Pump
« on: December 15, 2006, 12:12:07 PM »
Where is the best place to mount an electric fuel pump (rotary style)? Is closer to the gas tank better or is on the firewall ok?
Electric Fuel Pump
« Reply #1 on: December 15, 2006, 01:05:27 PM »
Under the tank on the passenger side is the best spot - they like to push not pull.
Electric Fuel Pump
« Reply #2 on: December 15, 2006, 03:28:59 PM »
The pump has a red lead and a black lead. I assume the red wire goes to a switched ignition source and the black to ground?
Do I need to use a fuel pressure regulator if using this pump?
« Last Edit: December 15, 2006, 03:30:16 PM by ancheez »
