Author Topic: Ida Jetting?  (Read 4531 times)
Offline neil68
Ida Jetting?
« on: December 01, 2006, 03:13:26 PM »
Looking for some ballpark jetting recommendations for 48 IDA Webers.  Our race track is at 3,280 ft altitude and my motor is a 2017 cc (maybe 2175 cc) with CB 044 oval-port 42 x 37, FK8, 1.4's, 1 5/8\" header and 42 venturies came with the IDA's.
Bruce, Alan...?
Thanks,
Neil.
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
Ida Jetting?
« Reply #1 on: December 01, 2006, 03:44:53 PM »
??? Which is it
I would suggest going down to a 40 vent.
Offline neil68
Ida Jetting?
« Reply #2 on: December 01, 2006, 04:56:06 PM »
Hi James,
I'm toying with putting in the slip-in 94's, but the motor is currently a 2017cc.
I was wondering whether the 42 mm vents might be too big, so I'll keep and eye out for some 40's as well.
Neil :)
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
Offline Cameron
Ida Jetting?
« Reply #3 on: December 01, 2006, 05:58:49 PM »
Hi Neil,
IDAs usually like a 60 idle jet, but you may be able to go smaller. 55? Higher altitude means lean it out.  You can always take the spark plugs out, and have a look. What do your spark plugs say?
This would be a good reason to finally go out a buy that AFR meter. Xmas is coming! Start throwing out hints.
Ida Jetting?
« Reply #4 on: December 01, 2006, 07:39:17 PM »
I bet it will respond nicely to a 60 idle jet.  Is it a 120 holder?
Do you have F7 tubes?  I'd start with a 160 main on the 42 vent.  Top it off with around a 180 air.
Offline neil68
Ida Jetting?
« Reply #5 on: December 07, 2006, 08:28:30 PM »
Thanks for the replies.  I haven't run the IDA's, so no spark plug readings yet.  Currently collecting a few parts (jet screens, jets, maybe vents, etc) so I might as well order these parts together.
Thanks again :)
« Last Edit: December 07, 2006, 08:28:55 PM by neil68 »
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
