Author Topic: Signals Help  (Read 4228 times)
Offline jeep-neil
Signals Help
« on: November 13, 2006, 09:35:31 PM »
im new to beetles i just bought a 1972 for 1100$ for a car to learn on and fix up. the cars signals worked when i bought it. now neither of them work, when i put one on the green signal indicator on the dash stays light up green. does that mean that a ight is out? and neither the left or the right signals work. sorry about all the questions, i do appreciate all the helpo you guys ahve done for me so far. thanks for any information you guys can think of.
Signals Help
« Reply #1 on: November 13, 2006, 10:24:42 PM »
start by checking your fuses and confirm that there is power at them, check your bulb filaments (to see if they're burned out) and check your grounds.
Signals Help
« Reply #2 on: November 14, 2006, 04:26:17 PM »
Like silas said, check your grounds, if you're local the wet weather lateley has probably gotten all your bulb sockets wet, causing corrosion, causing darkness. Find a bulb you know works and try it in the dark holes and see if they are burnt out or just need a cleaning.
