Author Topic: No Pm's  (Read 9690 times)
No Pm's
« on: November 07, 2006, 06:44:59 PM »
i know this is not priority but for some reason when erin logs in she has an error at the top of the page.
Warning: Missing argument 3 for member_no_usepm_bar() in /home/airspee/public_html/community-forum/Skin/s1/skin_global.php on line 142
this error won't allow her to log out most of the time but her private messages button (to send or recieve) does not show up at all.
when i'm logged in i have no problems,i tried clearing cookies ect but no luck for erin.
is this something on our end to fix or something for the forum master??
thanks for any help
russ
No Pm's
« Reply #1 on: November 07, 2006, 06:56:51 PM »
User is probably corrupted in the database, needs to be deleted and that would probably fix it, so yes the forum admin needs to do that.
No Pm's
« Reply #2 on: November 07, 2006, 09:18:30 PM »
There are a number of bugs in the board like IMG not working etc... it needs a shutdown and rebuild IMO
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
No Pm's
« Reply #3 on: November 08, 2006, 09:41:57 AM »
Everything's easy when you don't have to do it. If you'd like to rebuild it, feel free to do so.
The IMG tag issue came up when spell check was added. The two bits of code just don't work together. Geoff elected not to have me spend time trying to fix it. If there are other bugs, send me a list of specifics and I'll see what I can do.
Russ, what's erin's screen name?
Jason Hamilton
No Pm's
« Reply #4 on: November 08, 2006, 09:54:11 AM »
RoadRunner
thanks dude
No Pm's
« Reply #5 on: November 08, 2006, 10:24:07 AM »
Don't get your panties in a knot! Just stating a fact. You forget that I know a few things about boards and how they work, I know what is involved with coding and how much time it takes to debug them.
No Pm's
« Reply #6 on: November 08, 2006, 07:57:22 PM »
Jason,
thanks for any help getting me going again.
Is anyone else having this same problem?
or did someone put a curse on only me? :unsure:
anyways, thanks for going above and beyond,
erin
(logged in as russ cause i am not permitted to post or pm)
  • Admin
No Pm's
« Reply #7 on: November 08, 2006, 11:36:10 PM »
Erin, your issue should now be resolved. Let me know if it's not.
The problem was that you had not posted in over a year and the forum knocked you into "inactive" status.
No offence taken James, but I'm serious. If you want to fix the "bugs", go right ahead.
« Last Edit: November 08, 2006, 11:38:57 PM by jason_hamilton »
Jason Hamilton
No Pm's
« Reply #8 on: November 09, 2006, 06:39:11 AM »
I don't have enough hours in the day or I would help out. I know it takes constant tinkering to make this place run (kinda like a VW hmmmmmmm, coincidence or what!)
Offline RoadRunner
No Pm's
« Reply #9 on: November 09, 2006, 07:21:59 AM »
Thanks! Jason :)
Erin
