Clean and fast 1966 beetle, have owned it for the past 8 years.
Engine:
1914cc
DMS crank
SCAT rods with ARP bolts
Pauter Cam
Fresh steel cam gears
044's - 42x37 P/P by Pat Downs
SCAT 1.25 rockers
As41 case
Complete MSD ignition (Dizzy, blaster coil,leads,6AL,2 step, dial selectors)
Full flowed with external cleanable filter
New T04B (less than 200KMS on it)
1.5" header Draw Thru
40 DCOE
38mm Tial wastegate
New Turbosmart in car boost tee
3" stainless outlet pipe with tied in wastegate pipe & 12" resonator
Holley Black pump with 3/8 feed and return lines Aeromotive Reg (Return Style)
AN fittings everywhere
3.5 deep sump
Signature Berg breather box
Built KCR gear box with short axles
The Car:
Real Centerlines with 135's front and NEW MH DOT's in back
2" narrowed beam, dropped spindles fresh alignment
CE 90/10 front shocks
Fresh interior professionally installed ( sewfine and custom work )
New Autometer Phantom Guages
New Hurst Line Loc with trick engagement button in shifter
2 year old paint PPG CopperHead Pearl
Race weight fiberglass hood and removable fiberglass rear apron
Aftermarket wood steering wheel
Fresh brakes all around
H4 Headlights
Everything works, even the horn.
So much more to list please feel free to ask questions.
Lots of pictures available - want a specific shot just ask. Car ran a best of 12.03 @ 114 with only three runs of tuning and 15psi of boost - there is way more in it.
Will consider trades on a truck (must be registered in BC) or other interesting trades. I am not looking for another project.
