Author Topic: 02 May: Exhaust & Front Suspension  (Read 15985 times)
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
« on: May 03, 2006, 10:55:50 AM »
We've gotten a prototype of our billet beam retainer from the fabricators, and the exhaust has arrived from the ceramic coating shop, so let's have a peek...
In addition to looking great, ceramic coating adds years to the life of an exhaust system and helps keep the exhaust pipes from radiating heat.
A big nasty exhaust makes a big nasty sound...
That little button on the collector portion of a header is a removable bung. You can take out the bung and screw in an 0[size=8]2[/size] sensor for engine tuning with an air/fuel ratio monitor.
This is the Jamar aluminum beam installed. The king & link parts have been powdercoated silver, and you can see the red urethane bushings. Those are Carrera drag shocks, and that's a wide-five disc brake kit. All these parts are available from AirSpeed.
This is our billet beam retainer being test fitted. It will need a little material off the top for a perfect spacing match for the front body mounts.
Jason Hamilton
