Author Topic: Narrow Tie Rods For Narrow Beam  (Read 10354 times)
« on: July 07, 2003, 08:53:01 PM »
Hi all,
will be picking up some tie rods here shortly and was curious as to how to go about cutting them down for the 3\" narrow beam.
1 1/2\" on each tie rod? cut from the right hand side only?
then retap?
if this seems correct give me the A ok.
thanks russ
« Reply #1 on: July 07, 2003, 08:59:08 PM »
Hey Rusty, You got it, cut only one side and re tap. You will only need to cut 1\" off as there is enough adjustment for the other two inches.
Geoff.
