Author Topic: Oil Leak @#%^$&^$  (Read 4200 times)
Oil Leak @#%^$&^$
« on: November 05, 2005, 05:28:59 PM »
well I cleaned the engine and ran it . then I parked it and went under with a light. Looking under it at the back center of the block aprox 1\" toward the front there is one drip which I woud think is from the oil pump. right?
I also saw a bigger drip looking under the block from the back right side. There is a metal plate under the tubes and the leak is on the inside front of tha metal plate. I managed to glance at the fubes for No#1
 and No# 2 pistons and there is no evidence of any leaks. Tha leads me to believe tha it may be the oil presure relief valve  bu I could no find it.
If I remove the metal under the tubes, would this affect my cooling?
Any ideas?
Emilio
Oil Leak @#%^$&^$
« Reply #1 on: November 05, 2005, 06:01:23 PM »
yes.
Oil Leak @#%^$&^$
« Reply #2 on: November 05, 2005, 06:34:06 PM »
Yes, what?
Oil Leak @#%^$&^$
« Reply #3 on: November 05, 2005, 06:46:42 PM »
i answered your questions, yes I have ideas and yes it would affect your cooling.
Oil Leak @#%^$&^$
« Reply #4 on: November 05, 2005, 08:54:53 PM »
thanks
Emilio
