Author Topic: Ac Top 20  (Read 4607 times)
Ac Top 20
« Reply #30 on: August 26, 2005, 12:18:26 PM »
Be safe out there dood. Watch out for the elephant poop. I would imagine it would be hard to get off your shoes. Later fella.
Offline Cameron
Ac Top 20
« Reply #31 on: August 26, 2005, 12:20:21 PM »
I've saved the website you found and will hold onto the correction factors for next season - in the off season this winter I will be polling the ACTop20 membership for different changes that I am thinking of - I'll add yours to the list.
Hi James,
FYI Those correction factors look like they are for normally aspirated motors.
Turbo and supercharged cars have a different set of correction factors (much smaller), because they are not affected as much, by altitude.
Ac Top 20
« Reply #32 on: August 26, 2005, 12:22:55 PM »
Thanks for the info Cam - I wasn't aware of the difference. I will revisit that come winter time when the site gets geared up for the 2006 series.
Offline Cameron
Ac Top 20
« Reply #33 on: August 26, 2005, 12:35:16 PM »
James!
Found more track correction factors, from the official source.
NHRA Track Correction
Notice the bold print, about forced induction cars.
p.s. Mission Raceway is at sea level. No correction factor.
« Last Edit: August 26, 2005, 12:38:53 PM by Cameron »
Ac Top 20
« Reply #34 on: August 26, 2005, 12:48:26 PM »
Cool thanks Cam
Offline flat4
Ac Top 20
« Reply #35 on: August 26, 2005, 11:38:18 PM »
Its pretty funny that you can see where the elephants had been based on the amount of broken trees along the side of the road, and the \"speed bumps\" they leave behind.
I'm looking forward to altitude corrected numbers, fella.
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Ac Top 20
« Reply #36 on: August 27, 2005, 07:14:21 AM »
Well with the latest entry that came today a 14.26 second pass is what is needed to get on the list - better get out to the track everyone!
Ac Top 20
« Reply #37 on: August 27, 2005, 03:29:01 PM »
This would make my run a 14.381@90.92 based on 3500 ft altitude, 15.02 ET and a speed of 87 mph even
any other correction factors you want to add to that fred?  B)
Ac Top 20
« Reply #38 on: August 27, 2005, 04:05:34 PM »
yeah like the poor alberta flatlander needs a break correction factor!?  :P  :P  :P  :P  :P
« Last Edit: August 27, 2005, 04:05:51 PM by 1976BUS »
Offline Tom H.
Ac Top 20
« Reply #39 on: August 27, 2005, 08:58:52 PM »
Yeah I have a correction factor.
11.846, 113.17, and 1.518
all new personal bests.   :rockon:
And it was a  BIG Gas running fith the Super Shifters today at Bremerton
Offline Mowser
Ac Top 20
« Reply #40 on: August 27, 2005, 09:27:34 PM »
AWESOME TIME TOM.   :rockon:
Ac Top 20
« Reply #41 on: August 27, 2005, 09:52:38 PM »
BAM.
good job tom.
Ac Top 20
« Reply #42 on: August 27, 2005, 09:55:15 PM »
Who's the big dog now!!! Congrat Tom - that is going to light a fire under Alan's as for sure!
Offline Tom H.
Ac Top 20
« Reply #43 on: August 28, 2005, 08:53:37 AM »
There is still more HP to be had out of it. Stll running fat and I'm slowly approaching 12.6ish afr. I may be able to get the 60s into the 1.4 range but I may want the sissy sticks. My last pass when I did the 1.51, the front wheels were hanging aboot 2 feet in the air   :o. It was a fun day, only ran against V8s.
Its interesting, Alan's car and mine are so close to the same package, engines are very, very close , car weight is only 10 pounds different.  The 2 real differences are compression and gearing.
the next 2 races may not net me any new numbers as the tracks are 1000ish  feet (Yakima) and Vegas is ??? too high.
Ac Top 20
« Reply #44 on: August 28, 2005, 09:06:17 AM »
You turning Canadian on us
Offline AlanU
Ac Top 20
« Reply #45 on: August 28, 2005, 10:53:38 AM »
Thats awesome Tom.  I knew you had alot more HP in that engine of yours. With my compression I'll never be able to compete withya.
Killer times!!!
Ac Top 20
« Reply #46 on: August 28, 2005, 01:18:40 PM »
http://www.greatlakesdragaway.com/correcti...ionfactors.html
 :wacko:
Ac Top 20
« Reply #47 on: August 28, 2005, 06:08:19 PM »
NO...... he would have said .609 of a meter....hahaha :wacko:  I hate metric. Imperial for me.
Tom you rock, another example of wideband ,  FI,  and   and it's tuning abilities.  And here I putter on an old SU needle tapering it to make my car run better. Talk about stone age
