Author Topic: Welder Needed  (Read 1804 times)
Offline mike
Welder Needed
« on: August 08, 2005, 11:43:41 AM »
Hey guys!
I'm in need of an aluminum welder. I have some AN fittings that I need welded on to my valve covers.
Any recommendations?
Thanks!
Michael
Welder Needed
« Reply #1 on: August 08, 2005, 11:57:45 AM »
I know that Mike aka Gutterslug his bro does aluminum welding.
Welder Needed
« Reply #2 on: August 08, 2005, 11:59:53 AM »
I'm on holidays or I would get it done for ya at work - Chief Chassis should be able to, otherwise ditch the AL and go stock, then you just need a good wire feed mig.
Offline mike
Welder Needed
« Reply #3 on: August 08, 2005, 04:12:58 PM »
thanks james! I'll give chief chassis a call to see if that can do it for me.
 :rockon:
Welder Needed
« Reply #4 on: August 09, 2005, 03:37:28 PM »
Give Roseys fabrication a try. Hes done work for me and did a fine job to boot. Geoff should have his number.
Offline mike
Welder Needed
« Reply #5 on: August 10, 2005, 08:22:45 AM »
Thanks  snapper.
Calling around to see who can do it. Called a shop on the north shore first and they said they can't weld cast aluminium. Is this true?
Offline Mike Scott
Welder Needed
« Reply #6 on: August 10, 2005, 08:34:51 AM »
Are you welding on fittings for breather hoses?
Offline mike
Welder Needed
« Reply #7 on: August 10, 2005, 09:00:20 AM »
yup, weld on AN bungs for breather hoses.
Offline Mike Scott
Welder Needed
« Reply #8 on: August 10, 2005, 09:48:30 AM »
I guess you might already know..... I think you can buy threaded AN bungs with a nut and o-ring, similar to the ones found in the breather box kits.
Not sure if that's an option? Might be less expensive?
Just curious, is there a reason to weld in?
Mike
Offline mike
Welder Needed
« Reply #9 on: August 11, 2005, 03:24:58 PM »
Damn!... i didn't know they made those!  I'll have a look through the earls catalog to see if i can find them.
Not a fan of welding but i figure it was the only way of getting it done when it came to aluminium.
I'll definatley check out the o-rings.
Thanks!!!  :D
