Author Topic: 61 Project Strip Car  (Read 126583 times)
Re: 61 Project Street Strip Car
« Reply #90 on: August 01, 2010, 05:54:31 PM »
I was bored...........
Chris,
Is that an A-1 header?  that 1914 without the tin looks like a little baby in there!
« Reply #91 on: August 01, 2010, 07:51:29 PM »
That is an A-1 Lowdown header.
« Reply #92 on: August 01, 2010, 09:31:35 PM »
Is that a little nitrous hiding under that decklid?
« Reply #93 on: August 01, 2010, 09:41:27 PM »
I suppose if I had a decklid.....
« Reply #94 on: August 02, 2010, 05:23:25 AM »
Nice!  how much spray are you starting with?
« Reply #95 on: August 02, 2010, 09:13:59 AM »
Sorry, Kev its only for decoration.
« Reply #96 on: August 02, 2010, 09:40:44 AM »
I call bullshit on that! Hate to see you blow it up come Friday.
Offline Darren Dilley
« Reply #97 on: August 02, 2010, 10:03:04 AM »
lets just hope you can shift through all your gears on friday...  ;D
« Reply #98 on: August 02, 2010, 10:28:48 AM »
What are you trying to say Nancy?
« Reply #99 on: August 02, 2010, 12:33:25 PM »
No worries here. All of my gears are working just fine.
What Im trying to say is I think it is hooked up and I call cheater! :D
« Reply #100 on: August 02, 2010, 01:27:29 PM »
How am I cheating? :P
« Reply #101 on: August 02, 2010, 07:17:08 PM »
i know the tranny works ... but its the driver we are all worried about ...  :o
« Reply #102 on: August 02, 2010, 10:05:42 PM »
Thanks for your vote of confidence Mr. Supershifter.
Offline stefan
« Reply #103 on: August 03, 2010, 10:13:08 PM »
feel the love! :-* :-* :-*
Re: 61 Project Strip Car
« Reply #104 on: September 09, 2011, 12:09:47 AM »
So the latest update is long overdue.
Finally put in a roll bar. This comes with a lot of thanks to a few people. First goes to Fred (Flat4) for hooking me up with the main hoop and rear bars. Well worth the drive to see Fred and Tonya! Second thanks goes to Harold and crew at California Rod & Custom in Aldergrove for helping me out with space and time and all the great skills used to put this roll bar together. Here are some pics of the roll bar
Feel much better in the car now. In fitting the roll bar I had to lower the seat down to give me clearance for my big head. Being so low in the car is an odd feeling. Heres a pic to give you an idea of the height!
So on GCVWS weekend I learned a whole lot about running nitrous.....
Like how the car doesnt go when the bottle is empty, and how it doesnt go when you bend the full throttle switch and that nitrous is fun when its all working! Tried an easy launch at the end of the night with the nitrous engaged and pulled off a 110mph pass which was one of my goals for the year.
Thanks to Alan U for the pictures, I finally clued into the fact my cars suspension was hurting me (or at least I suspect so) so today I swapped out the stock torsion bars for some 28mm bars and lowered the back end of the car a bit and I raised up the front, seeing as the tires were rubbing when I would turn off the track. The stance looks better and in my quick pass around the block it feels alright. And some pics to see the difference in stance. Not the best comparison, but should give you an idea. Also have some new shocks coming for the back to help reduce the bounce back
If all goes well at test & tune today then I will hopefully be out for the supershifters weekend coming up.
« Reply #105 on: September 09, 2011, 07:10:52 AM »
New stance looks perfect! Good luck at the track!
Offline Mike Scott
« Reply #106 on: September 09, 2011, 07:41:35 AM »
Looks sweet Chris! I love how it gets a little more dailed in every year!  PDT_Armataz_01_37
« Reply #107 on: September 09, 2011, 02:44:18 PM »
Congrats to chris!!! I just heard he ran a 12.10!!! And the day is not over yet, 11.99 maybe?
« Reply #108 on: September 09, 2011, 07:09:25 PM »
New best ET 12.110 @ 109.22 MPH
Got my 60 ft times in to the 1.6's but ran into some clutch problems and then ended the day with a broken head stud!
« Reply #109 on: September 12, 2011, 07:32:43 AM »
Way to go Chris, breaking parts is all part of the fun of lowering the et's. Going 10mm studs next time, or were these 10mm already?
« Reply #110 on: April 09, 2012, 07:34:50 PM »
It has been a while....
Moved and dont have my own garage anymore but am trying to get one built.
In the meantime, Shane and Amanda have allowed me to move into the shop and start working on my car! Thank you!!!
So today, pulled the motor out and began the first rebuild ever and the repairs from last years breakage.
This is what stopped me last year, snapped off a head stud. Upon the tear down I did find pieces of a valve spring and that was confirmed with a visit to Darren's this afternoon
I split the case, no excess wear on the cam bearings, nothing looks out of place. I snapped pics of the lifters, after six years of track only use it appears they have some pitting/flaking
There will be a few upgrades this year, going to a 86C cam to try and get more out of the nitrous, upgrade the valve springs, more suspension work and some other goodies.
« Last Edit: April 09, 2012, 07:38:20 PM by VWChris »
« Reply #111 on: April 09, 2012, 10:23:09 PM »
It's great to see you working on this again. Mybe it will get me motivated to start on mine.....................maybe.
« Reply #112 on: April 09, 2012, 10:24:05 PM »
Just get it done.
« Reply #113 on: April 10, 2012, 08:31:58 PM »
6 years, and no tear down! wow well done sir well done! i hope she flys again this year, always a treat seeing your car run homeslice!
« Reply #114 on: April 10, 2012, 09:14:53 PM »
I may be naive about drag race engines, or maybe aircooled engines in general, but those lifters look pretty beat up for how many miles are on your motor. Is it the high revs and lack of cooling that causes that?
« Reply #115 on: April 14, 2012, 02:00:26 PM »
I suspect the wear, which appears more cosmetic than anything, is from a bit of float due to weak springs. So bigger springs it is!
Thanks to Darren for the case saver and install as well as the many pointers and tips on my rebuild and upgrade.
Im getting excited about this year at the track.
« Reply #116 on: April 14, 2012, 07:56:44 PM »
valeve float can lead to some of this wear but too heavy of springs will do the same by squeezing the thin layer of oil of the head of the lifter.
The wear you see is very common on high performance engines and even some stock engines when you run Scat/ Web lifters (among others)
The low zinc in todays oild play a big roll as well. Breaking in the cam and lifters on single springs is a good way to prolong the life but on race engines that only see the track this isn't done very often as cams and lifters get changed often during a season. Flaking lifters have been a big problem the past 10 years maybe more. Steel tool or schubek lifters are the best you can buy and allow you to swap cams without changing lifters as they do not wear (although there was a bad batch of steel tool lifters a couple years ago)
G.
« Reply #117 on: April 15, 2012, 06:24:29 PM »
Those pics are typical of Scat lifters.  The problem is the lifters themselves.  Don't use Scat and you'll likely be OK.
« Reply #118 on: April 15, 2012, 07:06:25 PM »
 It's not just Scat.
I pulled my 1835 apart and it was built in 1989 with german lifter and they looked just the same as well as we used to regrind orig lifters for use with HP cams and also saw some with this issue. I know Scat lifters appear to have more issues as I think they were a popular choice in the HP world until people started pulling engines apart and posting on the web.
I've sent back MANY MANY sets to scat over the years (while working at CIP) thats the reason I went to shubeck... $$$ but better in the long run.
If anyone is looking AlanU may have some of the Udo tool steel lifters as well.
« Reply #119 on: April 15, 2012, 07:10:32 PM »
They are not Scat lifters. Web with a Web Cam.
