Author Topic: Firing Problem  (Read 4374 times)
Offline KOOL-AID MAN
Firing Problem
« on: December 11, 2004, 01:31:22 PM »
So i just bought a new 009  distributer, put her in, using my points and condensor instead of the pertronix (for now)   so i have the firing order correct, and it is not 180 degrees out, but it wont fire, it just backfires if you crank it for long enough, anyone know what might be causing this? why my car wont fire? I have it setup pretty close to where the timming should be set, cause i used a test light to time it, my coil is also good, and points gap is too, im lost???
Offline Hoosier Daddy
Firing Problem
« Reply #1 on: December 11, 2004, 02:59:50 PM »
Pull a plug and turn it over to make sure you are getting spark...then check your firing order again.
Firing Problem
« Reply #2 on: December 11, 2004, 05:02:22 PM »
r u sure its not out 180 ??
Firing Problem
« Reply #3 on: December 12, 2004, 02:25:47 AM »
If you are replacing a stock vacuum dist, you have to switch all the plug wires by 90
Firing Problem
« Reply #4 on: December 12, 2004, 02:34:54 AM »
i was actually replacing another 009, all is the exact same. im gonna look at it again in the morning
Firing Problem
« Reply #5 on: December 12, 2004, 04:35:15 PM »
turned out it was 180 degrees out, i checked that before, but must have had something else wrong?? i dunno, im confused, but at least its good now
