Author Topic: Align Bore in Vancouver area  (Read 10365 times)
Offline hank
« on: May 25, 2024, 04:51:39 PM »
Hi
Is there any place to get a case checked and align bore done?
thanks
Hank
Offline hank
Re: Align Bore in Vancouver area
« Reply #1 on: May 26, 2024, 06:58:16 PM »
How about in BC?
Hank
« Reply #2 on: May 31, 2024, 10:12:17 AM »
I was digging for someone doing 36 horse align bore work, the closest was Seattle or Spokane
Offline hank
« Reply #3 on: May 31, 2024, 01:09:50 PM »
thanks bwaz
I have brother in law in Spokane
I'll talk with him and see if he can get some info
cheers
Hank
« Reply #4 on: May 31, 2024, 01:12:36 PM »
these guys Hank https://vintagevolks.com/
It's no steal at $310 U.S.
Offline hank
« Reply #5 on: June 01, 2024, 04:52:14 PM »
thanks Brian
looks like they have some interesting services
cheers
Hank
Offline Lanny
« Reply #6 on: June 03, 2024, 07:36:08 PM »
Concept 1 in Calgary
Offline hank
« Reply #7 on: June 04, 2024, 06:30:19 AM »
thanks Lanny
 that is a great shop , lots of eye candy
Hank
« Reply #8 on: June 04, 2024, 09:40:09 AM »
i checked with Concept 1, and got this reply. No we don't do align bores. Truthfully, we do it in house here, but only for engines we rebuild. The bearing quality and dimensions are such that each case has to be done to the exact set of bearings and crankshaft being used. We don't offer this service as it takes much longer than people would assume, and would not be profitable.  You should measure your case, check for cracks, corrosion, check lifter bore dimensions, and splay in the center to ensure it is actually a suitable case before considering getting it line bored. About 75% of the cases we see are beyond use for one reason or another.
Offline hank
« Reply #9 on: June 26, 2024, 09:14:00 AM »
FYI
I had the line bore done by AVR on the VW saw mill engine I'm rebuilding
looks good
Hank
« Reply #10 on: June 26, 2024, 12:48:06 PM »
thanks for the info Hank
