Air Speed Lounge
Lower OR raise beetle
Topic: Lower OR raise beetle (Read 11762 times)
wagonwx
AirSpeed Forum Member
September 04, 2023, 07:12:51 AM »
How long should it take to lower or raise the rear of a 1960 beetle if you know what you are doing and have done it before ?
My beetle is to low to drive and I need to raise it a notch. Thanks
52 split
Re: Lower OR raise beetle
September 04, 2023, 11:50:21 AM »
i guess your trying to see if a shop quote is close.right. 2hrs min, if inner and outer splines are needed for correct height. for you at home hours,half a day?? if no hoist
syncrobuggy
September 04, 2023, 11:25:57 PM »
Really all depends on if everything comes apart nicely or if bolts are seized or break. If one of the bolts breaks on the spring plate cover you can probably add a couple hours.
52 split
September 06, 2023, 08:54:39 PM »
for sure , always use heat. give the bolt head a good smack, then heat.go slow.
Air Speed Lounge
