Author Topic: Front disc weird problem.  (Read 12916 times)
Offline J A Red
« on: May 01, 2017, 11:10:11 PM »
I've converted my 56 bug over to front disc brakes. Been having a strange problem. After getting the lines bled I'll take the car for a spin. While at full steering lock (either direction) I loose all brake pedal pressure and have no brakes. Once the steering has straightened up I can get the brakes back by pumping the pedal. its Empi's front disc conversion kit w/ drop spindles, brake hoses aren't getting pinched or stretched that I can tell. Thinking of switching out the rubber hoses for braided to see if that helps. Any thoughts?
‘59 Light Green Double Cab
Sherbet Orange Meyers Manx
Re: Front disc weird problem.
« Reply #1 on: May 02, 2017, 07:32:18 AM »
Some sort of slop in the wheel bearings pushing the pads back when in a turn?, go drive around in a circle somewhere safe and see if the reservoir level rises.
« Reply #2 on: May 08, 2017, 10:20:47 AM »
Do you have a single or double cct master cylinder?
Offline J A Red
« Reply #3 on: May 13, 2017, 12:31:09 PM »
Bruce, I have a new dual master. The one that is recommended for this application.
Offline mitchy965
« Reply #4 on: May 13, 2017, 01:39:57 PM »
get the car on jack stands with the wheels off. have a pal on the pedal.spin the rotor by hand whilst holding pressure on the pedal and steering lock to lock.  some times a visual with help to locate the problem. i use a rounded jaw clamp tool to pinch off the hoses to isolate brake hydraulics. you can clamp off the rears to isolate the fronts to further narrow down the issue.
