Author Topic: Type 1 engine 091 Transaxle  (Read 13256 times)
Offline flat4
« on: March 08, 2016, 12:37:01 PM »
Does anyone have experience with this scenario? Using a type 1 engine with an 091 transaxle in a late bay?  If so, what mods need to be done to make it work?
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Offline flat4
Re: Type 1 engine 091 Transaxle
« Reply #2 on: March 08, 2016, 12:51:24 PM »
Thanks for the link. How does it work with a 6 rib 091 though. The bellhousing is deeper. Will the tin still fit? Does the input shaft need to be trimmed?
Water is for ducks
Sand Rail Project
Offline s3racing
« Reply #3 on: March 08, 2016, 01:00:04 PM »
Check out Kennedy Engineering. They helped me out with my clutch for my t1 to 915 transaxle conversion. I think i dealt with a Rob there. And Lori in the Office. They knew what fits to what.
« Last Edit: March 08, 2016, 09:34:28 PM by s3racing »
« Reply #4 on: March 08, 2016, 02:42:35 PM »
You'll have to spend some time reading that link, it's all covered.
It bolts up fine, but you'll have to shorten the input shaft (see link) and use the late bus starter. Your major issue will be the ratios if you are planning on a stock 1600, the 091 is geared for the longer stroke 2 liter and a 1600 will be a real toad in a bus.
