Author Topic: Vintage Speed Exhaust  (Read 13677 times)
Offline Thomas
« on: November 16, 2015, 07:46:57 PM »
Anyone else running the Vintage Speed Exhaust having trouble getting the exhaust gaskets to seal they supply. Not sure if I should try running some sealer with the stock gaskets or try different gasket materials. Thanks Thomas
Offline Russ
Re: Vintage Speed Exhaust
« Reply #1 on: November 16, 2015, 08:15:52 PM »
let me know how it goes as i was going to order one here in the near future
or how you were able to make it work
« Reply #2 on: November 16, 2015, 08:32:33 PM »
I'm not a fan of those exhausts all around
« Reply #3 on: November 16, 2015, 09:22:32 PM »
if i remember a fibre type gaskets? if so this may help.
not sure how thick or flat the flanges are ,hopefully ok.
as well trial fit with system bolted directly flat up agains heads without gaskets ,if it doesnt fit perfect without binding or tension it will always leak no mater what.
in the end im using copper gaskets with a thin film of high temp rtv ,never a issue
Offline Richard Kuczko
« Reply #4 on: November 19, 2015, 08:17:26 AM »
That's weird.  Mine fit perfectly on my engine. I've even taken it off and on constantly using the same gaskets.  Never a problem.  Great exaust by the way.  I find it worth it. I've been through those empi ones at least 1 a year.  This one is perfect
Offline Darren
« Reply #5 on: November 23, 2015, 08:54:35 PM »
Use the CB performace graphite ones. No leaky!
