Author Topic: Removing stuck inner bearing on spindle  (Read 13120 times)
Offline WhiteDonkey
« on: September 17, 2015, 08:44:42 PM »
Hi all and thx in advance
I have a king n link front beam and the inner race for the bearing is stuck on the spindle .....I've soaked and heated.......still does not remove .....any tricks or ideas pls
Re: Removing stuck inner bearing on spindle
« Reply #1 on: September 17, 2015, 09:18:26 PM »
Drill it then split it with a chisel
« Reply #2 on: September 18, 2015, 12:29:51 AM »
You should be able to clamp a bearing splitter into the groove between the bearing and the spindle. Then use a standard puller on the bearing splitter.
If that doesn't work, take an angle grinder and grind it at 12 O'Clock until it is super thin.  Then hit it with a hammer and it should split.
« Reply #3 on: September 18, 2015, 12:39:38 AM »
If he was running late and didn't get to it until 12:30, would it still work?
