Author Topic: 37mm Reamer for front beam bushings  (Read 12733 times)
Offline Rust
« on: November 28, 2014, 04:08:50 PM »
Anyone have a reamer for the front beam bushings in the Okanagan Valley area to lend or rent?
Installed new micarta bushings and the arms will not fit anymore.
I thought of sandpaper on a dowel but worried that I will not get a round hole.
Re: 37mm Reamer for front beam bushings
« Reply #1 on: December 16, 2014, 04:10:02 PM »
I'm looking for one also. The VW tool# is VW274A.
Offline Rust
« Reply #2 on: December 17, 2014, 01:15:32 PM »
I ended up buying one from Acklands Grainger.
https://www.acklandsgrainger.com/AGIPortalWeb/WebSource/ProductDisplay/globalProductDetailDisplay.do?item_code=WSW4LGT8
With my employee discount paid $68.
I am in the okanagan area if you need it. Worked great.
« Reply #3 on: March 19, 2015, 06:02:45 PM »
How did you find it for reaming the inner one? I ended up getting the factory tool which worked sweet. I'm not sure how you would be able to get the inners straight and true to the outer ones without a pilot like the OE tool.
