Author Topic: Type 4 motor in split bus  (Read 5469 times)
Offline iceneweb
« on: July 21, 2014, 04:41:10 PM »
What are the pros and cons of putting a 1.7,1.8 or 2.0 motor in a split bus?
1971 Westfalia Campmobile
Re: Type 4 motor in split bus
« Reply #1 on: July 21, 2014, 06:40:37 PM »
Pros: lots of torque and almost bulletproof in that application.
Cons: your wallet better be up to the task if you want to do it right without hacking the bus: http://type4store.com/conversion-cooling-systems.html
Offline iceneweb
« Reply #2 on: July 21, 2014, 06:47:29 PM »
Woah, I didn't realise there was so much work involved. In my naiveity, I figured some different tin would be all that is required.
It was just an idea . . . ;)
Offline 52 split
« Reply #3 on: July 22, 2014, 06:13:08 AM »
you can do it with t1 tin that you have laying around in your shop.  see attached pic.cost me  under a hundred to do.
« Last Edit: July 23, 2014, 09:42:44 PM by 52 split »
