Technical
Engine Tech Forum
Type 4 motor in split bus
Topic: Type 4 motor in split bus (Read 5615 times)
iceneweb
July 21, 2014, 04:41:10 PM »
What are the pros and cons of putting a 1.7,1.8 or 2.0 motor in a split bus?
Thanks!
1971 Westfalia Campmobile
BUSDADDY
Re: Type 4 motor in split bus
July 21, 2014, 06:40:37 PM »
Pros: lots of torque and almost bulletproof in that application.
Cons: your wallet better be up to the task if you want to do it right without hacking the bus:
http://type4store.com/conversion-cooling-systems.html
iceneweb
July 21, 2014, 06:47:29 PM »
Woah, I didn't realise there was so much work involved. In my naiveity, I figured some different tin would be all that is required.
It was just an idea . . .
52 split
July 22, 2014, 06:13:08 AM »
you can do it with t1 tin that you have laying around in your shop. see attached pic.cost me under a hundred to do.
Last Edit: July 23, 2014, 09:42:44 PM by 52 split
Technical
Engine Tech Forum
