Author Topic: Weber IDA 3.2 needle valves  (Read 4419 times)
Offline neil68
« on: June 23, 2014, 06:41:12 PM »
IDA guru's:
I've upgraded to an 8 mm fuel tank outlet, Carter rotary pump, -6 AN fuel lines, IDA top entry fuel connection (-6 AN) and 3.2 mm fuel inlet needle valves. Also, enlarged the inlet port inside the carb body where the stock Weber fuel filter sits (removed the filters).
So far I've enlarged the inlet hole to 11/64" which is ~4.4 mm.  Can't seem to find any recommended size for drilling these inlet ports for 1/4-mile racing.
Any recommendations?
Thanks!
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
