Author Topic: Help with dual Dellortos and vacuum advance  (Read 5210 times)
Offline Vancity
« on: June 06, 2014, 10:40:46 PM »
73 Super Beetle dual port engine in a 65 Single Cab. Dual Dellortos not sure what size or model right now. The distributor is a Bosch JFU 4 with vacuum advance
The carbs both have a plugged off fitting so I'm assuming these are vacuum fittings.
Wondering how to hook up the vacuum lines from the distributor to the carbs if its possible, advice appreciated :)
Right carb
Left carb
JFU 4 distributor
« Last Edit: June 24, 2014, 05:44:35 PM by Vancity »
Offline Darren
Re: Help with dual Dellortos and vacuum advance
« Reply #1 on: June 18, 2014, 10:39:38 AM »
Yes the hose from the dizzy goes to that plugged off port on the left carb.  ( you only will need to connect it to the one side )
Cheers
Offline Vancity
« Reply #2 on: June 24, 2014, 05:51:31 PM »
Ok cool. I ended up putting a tee in and connecting both sides but haven't even ran it since. Borrowing a timing light tonight and will change that out.
Thanks a lot!
