Author Topic: Fuel Tank Outlet Gasket or Sealant  (Read 4739 times)
Offline neil68
« on: April 04, 2014, 06:17:28 PM »
I'm replacing the stock fuel tank outlet with a larger 8 mm outlet, similar style to OEM.
I can't seem to locate a "larger sealing gasket" to fit over the spout...should I use "form-a-gasket" that is suitable for gasoline?
I might be able to drill out the stock gasket, but I've already destroyed one of them.
Thanks.
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
Re: Fuel Tank Outlet Gasket or Sealant
« Reply #1 on: April 04, 2014, 07:12:50 PM »
gasket or weld on bung
