Brakes Forum
1970 class11 look
Topic: 1970 class11 look (Read 9982 times)
purple turd
1970 class11 look
August 26, 2013, 05:37:27 PM »
So I have 70 bug bodylifted running 235 tires all around. The brakes seemed a bit to hard so I replaced everything....shoes, wheel cylinders, springs, drums, lines, hoses, master cyl. It seems to take way too much force to stop. Normal...?
bwaz
Re: 1970 class11 look
August 26, 2013, 08:21:16 PM »
235 tires will take a lot more effort to stop for sure!
purple turd
August 26, 2013, 09:26:30 PM »
I may try a disc conversion if I can find a reasonably priced kit thats not junk. I used napa shoes so maybe another brand of friction
purple turd
August 28, 2013, 08:01:39 PM »
Not reallysure if anyone cares but after replacing pretty well a complete brake system on my beetle it still did notstop the way it should. 4 wheel drums and probably too heavy. I started looking into discs. Theres not much out there except empi ($200) or the high end stuff ($1400) just for fronts. Ive used empi parts before and seen the absolute crap that is produced.you should have seen the body lift I threw in the steel bin. (The scrap guys didnt even want it). Anywaysorry for the empibashing. I installed the $200 empi disc brake kit with cast caliper mounts, rotors, pads, calipers and hardware. It took just over an hour.everything fit. I havent read the instructions yet. The car stops well and finally it doesnt take a body builder to push the brake pedal. The good parts...I can put it back to stock.there was not a single part missing, nor did I have to modify anything on the car. It stops. The bad...not a fricken thing except I now have a bunch of leftover new drum brake parts.
bwaz
August 28, 2013, 10:27:07 PM »
Did you put in a new master cylinder too?
purple turd
August 29, 2013, 07:24:39 AM »
New master was put in a week ago. Most after market listings show the same master for disc or drum. I used a raybestos one.
purple turd
August 29, 2013, 01:58:40 PM »
anyone ever done the front to rear wheel cylinder swap?
purple turd
Reply #7 on:
September 03, 2013, 03:53:06 PM »
Swapped front wheel cyls to rear.stops even better now but pedal travel would scare someone who hasnt been warned. Anyone have any suggestions?
Hansk
Reply #8 on:
September 04, 2013, 08:36:38 AM »
I've found that drums seem to take time to seat in and pedal feel and pressure improve with time.
purple turd
Reply #9 on:
September 04, 2013, 07:13:43 PM »
I hope so. My 4 wheel drum buggy brakes are right at the top even when theyre out of adjustment. The disc drum bug has about 3 inches before they do much. Still not pedal on the firewall just so much different from the other car. The beetle weighs 1900lbs ...the buggy weighs 1375
Brakes Forum
1970 class11 look
