Author Topic: More VW parts Beetle and Bus  (Read 1672 times)
Offline VWinTHEblood
« on: May 23, 2013, 07:49:54 PM »
More parts for sale, I'm moving into Vancouver in June so I need to get rid of this stuff. No reasonable offer refused, buy the whole package and I will make a great deal for you.
2 complete 30 pict 3 carbs $10 each
2 95% complete carbs one is 30 pict 2 the other is a 30 pict 3 $5 each
bosch 031 centrifugal advance distributor plus extra cap and a set of leads $20
bus tail lights $5 each
bus reverse lights $5 each
bus front signal lens $10 for all 3
bus front beam bump stops $5 for the pair
bus interior light $1
rocker covers with bails $5 for all 3
misc small cooling tin $5 for all 4 pieces
bus door pulls $2 for the pair
WORKING jetta ignition coil $2
bay bus fuel tank vent hardline $3
bus front transaxle bracket $2
type 1 to type 2 engine cradle adpater and oil pump cover $2
dished generator cooling tin backing plate set for 38 amp generator found in early bays $15
oil cap, input shaft, oil cooler adpater and master cylinder boot, FREE
Re: More VW parts Beetle and Bus
« Reply #1 on: May 23, 2013, 08:06:09 PM »
Forgot to mention that I'm in Abbotsford. Thanks
« Reply #2 on: May 25, 2013, 08:32:47 PM »
All the lights and lenses are sold. Open to any offers on the rest
« Reply #3 on: May 26, 2013, 12:43:46 AM »
give ya 10 for the gen. backing plate....
« Reply #4 on: May 29, 2013, 07:38:32 PM »
Sounds good, ill put that aside for you as well.
Open to any offers on the rest of the parts, I need to clear it out!
« Reply #5 on: May 30, 2013, 07:20:16 PM »
Cool, I live over on the island....should be over for the abbotsford tradex swap whenever that is?
« Reply #6 on: May 30, 2013, 10:02:02 PM »
that was last week I think Josh, the Coastal one?
« Reply #7 on: May 31, 2013, 08:08:57 AM »
Chit!!!  ??? ???
