Here are some more parts that I'm clearing out, lots more to come shortly. I'm located in Abbotsford.
German 25hp-36hp valve cover gasket set and oil strainer gasket set. $10
NOS German 25hp-36hp fuel pump base gaskets. $15 for all 9 of them
NOS 30 PICT-3 idle cut off solenoid, this part is NLA and specific to the 30 PICT-3. $15
NOS generator brush set. $4
NOS German accelerator pump diaphragms for the 28 pict-34 pict carburetors. $5 each, I have 4 in original packaging
NEW Genuine VW fuel pump flange. $4
NEW Brake fluid reservoir for bay windows 69-72. $15
NEW German 8mm valve adjusting screw set with nuts. $16
NEW Genuine VW three prong brake light switch. $4
NEW distributor clamps. $3 each
NEW Bosch 009 condenser. $4
NEW Bugpack header flange. $5
NEW Continental generator belt BEETLE 67-73 GHIA 67-73 BUS 67-71. $5
NEW Genuine VW type 4 intake spacers. $2 for the pair
NEW clutch cross shaft repair kit, this is the hard to find complete kit with all the bushings. It fits beetle,bus,and ghia 61-70. $10
NEW Stant gas cap fits Jetta 92-99. $5
