Author Topic: Kelowna Swap Meet Needs and Wants  (Read 5295 times)
Offline Al H
« on: May 12, 2013, 08:57:22 PM »
What vw parts do you need? Please post so we can have a successful event this upcoming Saturday
Offline rekka
    • Radwerx Creative Inc
Re: Kelowna Swap Meet Needs and Wants
« Reply #1 on: May 13, 2013, 07:59:09 AM »
If anybody has some BAD IDF carbs or similar I can modify to use as throttle bodies that would be great. Not looking to pay as much as good working carbs obviously. Cheers.
« Reply #2 on: May 13, 2013, 08:20:43 AM »
68-72 bus. Rear bumper, rear apron, and engine lid
Offline rekka
« Reply #3 on: May 13, 2013, 08:29:20 AM »
I have all three of those. I'll PM you.
Offline flat4
« Reply #4 on: May 13, 2013, 03:01:25 PM »
I have a 57 Oval (everything but bumpers/engine) that I'd make the trip to drop off.  Needs channels and rear 1/4s, but has convertible/semaphore front fenders. Good aprons, 4 tab hood, seats, radio, gas tank.  It's still a project though.
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Offline flat4
« Reply #5 on: May 13, 2013, 03:04:53 PM »
I've also got that 901 gearbox and bug@5speed nose cone conversion kit available.
Water is for ducks
Sand Rail Project
Offline Richard Kuczko
« Reply #6 on: May 13, 2013, 04:59:07 PM »
Slammed bus.   I have ur engine lid. Has 1 small dent. It's all yours. We will be there by the motor home
« Reply #7 on: May 13, 2013, 05:03:20 PM »
I need a 59 Beetle gas pedal...70 bay window bus lower ready to weld body metal.....also I will be bringing 62 beetle engine lid and hood...lots of engine tin for 1200 and 1300cc engines. And a bunch of smalls
« Reply #8 on: May 13, 2013, 07:03:49 PM »
Ohh and long shot but a bay window sliding door interior door panel
Offline rekka
« Reply #9 on: May 13, 2013, 08:02:47 PM »
Perfect, as I don't have on after all.
Offline lildunebuggy
« Reply #10 on: May 13, 2013, 09:42:43 PM »
Warrior beam with towers to off road baja
Offline OldnShitty
« Reply #11 on: May 14, 2013, 09:13:09 PM »
Richard, I will bring a bunch of bus metal for you to see.  Also got a complete drum to drum 1964 big nut bus trans if anyone is looking for one.
I will be bringing a trailer full of air cooled parts.
Offline HotSauce
« Reply #12 on: May 14, 2013, 09:13:09 PM »
Couple things I'm looking for my 60 bug. Snowflake bulb holders, good small back window rubber that excepts trim, engine bay seal and fire wall seal, mag wheel lug nut set for wide five drums, grey mohair roof liner, and a nice pair of running boards they don't have to be oem.
Luke I had your father
Offline getgeoff
  • Geoff
« Reply #13 on: May 15, 2013, 05:57:18 AM »
I have a complete oval window door that I could bring down. I think its the driver's side.
60 11 Window bus Lt grey
55 Wolfsburg Kombi doveblue
55 Beetle ultra maroon
Offline aircooleddave1965
  • Aircooled addicted
« Reply #14 on: May 15, 2013, 06:57:10 AM »
I will be bringing a Single cab full of early body parts, a couple complete Beetle drivers doors, deck lids, bumpers, front fenders, two sets of good splity ice pic doors, a set of window cargo doors, bay window doors and hatches, deck lids, assorted rims, and a bunch of type three stuff left over from my Notchback restoration and some smalls.
I also have a bunch of IRS transmissions, a 944 rear torsion suspension and couple of Bay window transmissions, that I could bring if some one is interested.
'57 356 Speedster
'63 Scab
'73 High top Bay
'65 Kombi
‘70 Vert
« Reply #15 on: May 15, 2013, 07:25:28 AM »
I'm looking for a 71 bus bell housing or core trans, have any?
« Reply #16 on: May 15, 2013, 08:59:01 AM »
Richard! Thank you so much! I will be there. U just made my day!
« Reply #17 on: May 15, 2013, 09:00:27 AM »
Isn't that just an 002 tranny G?
« Reply #18 on: May 15, 2013, 09:59:04 AM »
Yes but 71 has the late t/o bearing to match my pressure plate and no upper bell housing mounts like the 72.
Offline rekka
« Reply #19 on: May 15, 2013, 12:56:26 PM »
If anyone has link pin shims for a 65 bus, i need half a dozen. Cheers.
« Reply #20 on: May 15, 2013, 02:02:54 PM »
Price?
What's the condition of the 901 box?
Do you know the condition of the syncros for each gear?
Has it been opened up for any repairs?
Lastly, what's the code stamped into the bottom?
Factory 901 nose cone and Bug@5speed nose cone, or just the Bug@?
Offline flat4
« Reply #21 on: May 15, 2013, 02:45:57 PM »
Hi Dave.
It came out of a running/driving 912 (64-65 I think) so it has all 5 close ratio gears.  The PO upgraded to a large type 4 for is 912, and swapped gear boxes, as this one was for the original small engine.  The PO is a friend and very meticulous.  I don't think he would have sold me the gearbox if it was a POS.  I haven't opened up the box or done anything but mount the rear Bug@5speed rear mount and swap nosecones (for fitting)
I did pick up some tall 5th (0.72 or 0.77) gears as I was going to use 5 as the actual OD for cruising.
I have the original nose cone, the original front mount, original axle flanges,  the Bug@5speed kit including nose cone, rear mount, front mount, clutch guide tube, bus chromoly axle flanges, bus CV's (I have THING stubs too if that helps the decision) and the shifter (super nice piece).  All I was missing was a 911 shift rod.
Kit wasn't cheap, but it's not doing me any good sitting at home.  It's very unlikely I'll use it.  I'd be happy with $1800 for everything, but no one said I had to go away happy.
I can get you the code tonight (late tonight)
Water is for ducks
Sand Rail Project
« Reply #22 on: May 15, 2013, 05:32:19 PM »
I could use a ride down to the coast for a doublecab rear seat and pedestal, there's beer or gas money involved :) I was planning to go fetch it myself but the weekend is starting to get out of control :(
Offline Al H
« Reply #23 on: May 15, 2013, 05:33:56 PM »
A few of the carbs Im bringing to the swap on Saturday
« Reply #24 on: May 15, 2013, 06:19:05 PM »
Thanks shity.  I will be looking for u
« Reply #25 on: May 15, 2013, 10:41:47 PM »
I have two good Bay trans. one was out of a 69, the other I think is a 71 what should I look for or do you want a number off it?
'57 356 Speedster
'63 Scab
'73 High top Bay
'65 Kombi
‘70 Vert
« Reply #26 on: May 16, 2013, 07:32:36 AM »
You can snap a pic of the bell housing throw out bearing area and text to 604-760-5899
Thanks.
Offline Al H
« Reply #27 on: May 16, 2013, 09:26:58 PM »
Heres a smaill list of things Ill be bringing to the show
1 set of Weber 42 dcnf carbs
2 set of 40mm Kadrons
3 34 pict carb intake and end castings for 1600 dual port
4 lowered shocks for ball joint frt end
5 Misc shocks
6 Scat Drag Fast shifter almost new
7 New bus and beetle wheel cylinders
8 Early standard beetle 3 spoke steering wheel
9  2 front Pressed bumpers
10 1 rear pressed bumper
11 4 4 bolt centreline wheels
12 Misc early screw terminal electrical switches
13 single weber 44 idf carb
« Reply #28 on: May 19, 2013, 10:36:31 AM »
That was a fun morning. Great group of people as usual. Nice to meet many of you. Got some wicked deals!!!!! Thanks
« Reply #29 on: May 19, 2013, 12:44:42 PM »
Don't worry I won't forget about your hinges
