Technical
Engine Tech Forum
Question about bearings and crank dimensions
Topic: Question about bearings and crank dimensions (Read 4645 times)
Porschedave
March 20, 2013, 09:44:00 AM »
Hi Folks
What oil clearance can I expect between the crank main bearings and the crank journals? The bearings are new and sized to match the machined crank. With my measurements I get 3 thou and this seems consistent with Jim Martin's engine-build resource but I thought that I'd ask around before I assemble this engine (for my '65 notch restoration).
Thank you.
Dave
1958/9 Karmann Ghia build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139
jim martin
If something is priced to good to be true ,do yourself a favour. DONT be a IDIOT and BUY IT
Re: Question about bearings and crank dimensions
March 24, 2013, 08:50:51 AM »
sounds like your on the right track,always happy to hear someone assembling there own motor , if you have any concerns contact me and i will be glad to help
the 'WOK" June 2006 Hot VW's feature car 9.830 sec at 143.44 mph.
Sponsored by :
LUCAS OIL PRODUCTS
www.lucasoil.com
Porschedave
March 24, 2013, 10:06:43 AM »
Hi Jim
Thank you for your post and offer to help. I have read your engine-build thread a number of times and in fact am following all of the instructions regarding measurement in preparation for assembly. After a bunch of time I think that I have successfully measured the bearings in the case, the journals and compared the two as well as the cam and the oil pump. I still have to do measure the rods. I have weighed them and selected a set that is pretty close to the same weight and thenI think that I am good to assemble. This is for a type 3 engine, 1776 with a full-flow setup.
Thanks again for your for offer and for the build sheet.
Dave
Technical
Engine Tech Forum
