SOLD !!! Thanks for looking
1964 VW Bug $8,000
-Everything in perfect working condition
-12 volt conversion, new battery, radio delete plate
-no rust, new paint, car from Seattle
-new headliner, seat covers, door panels, carpets, underlay and sun visors
-new rubber floor mats front and rear and new running boards
-new seat belts, dome light and package tray
-Empi trigger shifter, new shift rod bushing and coupler
-new wiper pivot shaft kit, arms and blades
-new German window rubber kit and chrome, without wood slat roof rack
-new wiring harness front to back
-new BRM replica’s and excellent tires
-new CB Performance 2” narrowed adjustable beam, new tie rods
-new king and link pins with drop spindles
-new wheel bearings and new shocks front and rear
-fresh rebuilt transmission with newer nose cone with back up switch
-new German axle boots, bowden tube and bracket
-new bumpers with 1967 reverse lights
-new German cardboard trunk liner and ABS plastic wiring cover
-new gas tank and all steel and rubber fuel lines throughout including tunnel
-new brakes ;( new wheel cylinders, brake shoes, master cylinder, rubber flex hoses and metal lines)
-new motor ,built and tuned by Kroc 1776 dual kadrons , 69mm counter weight crank, heads 3 angle valve job mild port clean up, Engle 100 cam and lifters , pertronix vacuum advance distributor
http://vancouver.en.craigslist.ca/rds/cto/3126484418.html
