Author Topic: 1974/75 Westfalia Bed Frame and Seat Mechanism  (Read 819 times)
Offline pittwagen
« on: July 07, 2012, 08:48:11 PM »
Westfalia bed brackets and wood frame/seat mechanism.  I should have most of the bolts etc. as well.  Front face panel is not included but I can supply the dimensions that can be easily cut from a piece of 3/4" plywood.  You will need to supply the two seat cushions and the rear cushion as well as the seat cover material of your choice.
This provides full underseat storage and is a much better use of space than the Z bed. The bed is the largest of all Bay Window Westfalia beds.  It is full width - about 54." wide
This will fit all 68-79 Bay window buses as well as earlier split window buses {with a slightly smaller front face panel.
$60.  Local pickup only. I'm in Pitt Meadows.
« Last Edit: July 07, 2012, 09:40:08 PM by pittwagen »
