Author Topic: WTB Big nut reduction gear boxes and extension/filler for large bus gas tank  (Read 2104 times)
Offline pete-stevers
Looking for Reduction gear boxes for improved ratio for top speed...
and looking for a filler neck extension  for a later/large bus tank and gas cap
thanks a ton!
Tell us more about this "filler extension", split tanks are one piece withe the filler neck built in, bay tanks use a separate filler neck. What are you trying to do?
Offline lildunebuggy
you will know if this is to work for you.
Busdady..looking to put a late model tank into a split Sc
Hey Steve why dont you try jeff450x, I know that he had a set that even had chrome axle tubes, don't know if he still has them but it's worth a try.
Andy
Hey Bussdaddy...would you have any filler necks for a late  model bus tank
I'm sorry I'm fresh out of 68-71 filler necks right now, but if you want to install it in a splitty you really need a rotted out split tank to saw the filler neck off of, bay fillers mount differently and use a different cap, they work but the split filler is a better fit. 72-79 won't work at all for your needs as they are welded into the bus and in a completely different spot from the early models.
Alp and Steveo were parting early bays a while ago, maybe they have some leftovers?
thanks Steveo is coming over fri nite!
