Author Topic: WTB - short axle  (Read 1508 times)
Offline splitwindowman
WTB - short axle
« on: May 19, 2012, 03:04:18 PM »
Does anyone have a good used short axle for an early swing axle tranny? Anything pre 1966 will do. Hoping to find something local before I order from Rancho. Maybe $20?
Thx, Jason
Offline rustybus
Re: WTB - short axle
« Reply #1 on: May 19, 2012, 10:22:11 PM »
i might i can check tomorrow when i get home from work. how local do you want it to be i'm in abby
chris
« Reply #2 on: May 20, 2012, 09:14:37 AM »
Hey, I'm in Abbotsford as well. The axle should measure 26 1/2" end to end. The spade end on one of my has some very deep gouges in it from wear. Just hoping to find a nice clean replacement.
Offline rustybus
« Reply #3 on: May 20, 2012, 07:31:09 PM »
ok i still have that short axle trans. wasn't sure if i scrapped it cause one axle was  broken . i will pull the other axle tomorrow morning to see if its good enough. if it is you can have it for free.
« Reply #4 on: May 20, 2012, 09:14:50 PM »
Jason, Try and get the correct side axle L or R as it's better to keep them in the same rotation (if you swap them side to side) other wise they can break under hard load. I don't know if ytou have a big engine going in but just to be safe. They will be marked with either a pink or blue dot.
Offline rustybus
« Reply #5 on: May 21, 2012, 08:32:25 AM »
i didnt know that. the one i have is a drivers side . i just havent gone outside to pull it yet
« Reply #6 on: May 21, 2012, 09:42:52 AM »
Thanks Geoff, I completely forgot to mention left or right. It's my drivers side (left) that is worn out. Thanks for the offer rustybus, I just might be in luck!
Jason
Offline rustybus
« Reply #7 on: May 21, 2012, 12:15:33 PM »
its out looks good . i emailed you my address and cell#
Jodasa
« Reply #8 on: May 21, 2012, 03:19:10 PM »
You hooked him up!
Nice one rustybus!
Offline Russ
« Reply #9 on: May 21, 2012, 04:32:13 PM »
do the dots correlate to a left or right side?
example blue left side?
« Reply #10 on: May 21, 2012, 04:36:00 PM »
Well I popped in to see Chris and he had a great axle for me - thanks Chris!
My axles and the one I got from Chris didn't have any of the colors marks Geoff mentioned. Thank goodness I marked mine left and right when I removed them.
