Author Topic: Engine codes  (Read 33414 times)
Engine codes
« on: July 27, 2011, 01:56:10 PM »
Here is a list of engine codes for T1 blocks, credit to thesamba.
Type 1
Code Year Engine/Notes
1- Pre-Jan., 1956 25hp/36hp
1- prefix indicates Type 1 and is not part of the sequential engine number.
2, 3, 4, 5, 6, 7, 8, 9 55-65 1200cc, 36hp/40hp
D0 1966/67 1200cc
F0 1966/67 1300cc
H0 1967 1500cc
F1 1967 40hp
E0 1967 M240 low compression 37hp
L0 1967 M240 low compression 40hp
H5 1968/69 1500cc
B6 1970 1600cc - dual relief, single port
AB 1971/73 1300cc - dual port
AE 1971/72 1600cc - dual relief, dual port
AH 1973/74 1600cc - 8mm head studs with case savers
AJ 1975-1979 1600cc - fuel injected
Type 2
20- Pre-Jan., 1956 25hp/36hp
20- prefix indicates Type 2 and is not part of the sequential engine number.
O 1963/64 1500cc - no cam bearings
H 1965 1500cc
HO 1966/67 1500cc
B5 1968/69 1600cc - single relief
B5 1970 1600cc - dual relief
AE 1971 1600cc
CB 1972/73 1700cc - dual carb., manual transmission
CD 1973 1700cc - dual carb., automatic transmission
AW 1973/74 1800cc - dual carb.
AW 1975 1800cc - fuel-injected
AP 1974/75 1800cc - European only
ED 1975 1800cc
GD 1976/77 2000cc
CJ 1976-1979 2000cc - European only
GE 1978/79 2000cc
CU 1980-1983 2000cc - Vanagon style
CV 1980-1983 2000cc - Vanagon style
Type 3
O 1961-65 1500cc
K0 1966-1972 1500cc - 54hp
M0 1966-1972 1500cc - M240 low compression 52hp
P0 1966/67 1600cc - M240 low compression 50hp
T0 1966-1973 1600cc
U0 1968-1973 1600cc - fuel injected for USA
U0 1970 1600cc - dual-relief case
U5 1971-1973 1600cc - 7.7:1 compression - US/Canada M239 California fuel-injection
X 1972 1600cc - 7.3:1 compression - California
Type 4
V 1969 1700cc - 68hp
Z 1969/70 1700cc - 7.8:1 compression - 68hp, dual carb., automatic transmission
W 1971 1700cc - 8.2:1 compression - 80hp
EA 1972-1974 1700cc
EB 1973 1700cc - California only, fuel injection
EC 1974 1800cc
AN 1974 1800cc - 8.6:1 compression
AT 1974 1800cc - European only, dual carb.
Porsche 914
W 1970/71 1700cc - 8.2:1 compression - 80hp
EA 1972-1973 1700cc
EB 1973 1700cc - 7.3: compression, California only, fuel injection
EC 1974 1800cc - California only, 7.6:1 compression
AN   1800cc - 8.6:1 compression
GA 1973/74 2000cc - 7.6:1 comporession
GB 1973-1976 2000cc - 8.0:1 compresssion
GC 1975/76 2000cc - 7.6:1 compresssion
V0   1700cc - European-only
1800cc - European-only
2000cc - European-only
Replacement cases
These cases were VW engine cases that were sold from VW but never issued in an actual production vehicle.  All are dual-relief cases with 100mm oil passages.
Example:
Information from a 5/73 USA service bulletin issued 5/73:
Engines with the re-manufactured symbol, a letter, a number and ending with X, indicates a VW Exchange engine.  Before Oct., 1968 the X was not stamped onto the block.
From April of 1972 Shortblocks were sold with the VW remanufacture symbol followed by a letter. No numbers were used, you were to stamp in the old engine number.
F1 1300/1600
F2 1300/1600
DO 40hp if last digit is "X"
D1 40hp part
AD 1600
AK 1967-1974 1500/1600
AM 1600
AS  Sometimes seen listed as Super Beetle case for 1973-onward
Exchange engines
These engines are normally marked with a VW recycle symbol and an X at the end.
Example:
Offline Cameron
Re: Engine codes
« Reply #1 on: July 27, 2011, 06:01:12 PM »
"Replacement cases
These cases were VW engine cases that were sold from VW but never issued in an actual production vehicle.  All are dual-relief cases with 100mm oil passages."
100mm oil passages? Wow! That's a lot of oil space.
Offline buggal
  • April McNicol
  • 1972 STD Beetle project
Re: Engine codes
« Reply #2 on: September 17, 2011, 08:10:25 PM »
I know this is an old post, and my question kinda dumb, but I have an AD case. Is that a good thing?
Offline neil68
Re: Engine codes
« Reply #3 on: September 17, 2011, 09:16:56 PM »
Just wanted to add that AM cases were also factory engines for some/all 70's Things 1600 cc.  I know this from several Things that were sold by our local dealer back when I was still in high school...Beetles had AH but Things had AM codes...
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
Offline bugbuzz
Re: Engine codes
« Reply #4 on: September 10, 2016, 08:02:39 PM »
Found a engine in a 69" with "AK136466" stamped on block under oil filler.. What is it? The owner claims its a Porches 911??
I'm trying to buy the car but....?
Re: Engine codes
« Reply #5 on: September 10, 2016, 09:22:25 PM »
914 numbers
Re: Engine codes
« Reply #6 on: September 10, 2016, 09:27:34 PM »
912
Re: Engine codes
« Reply #7 on: September 10, 2016, 09:30:25 PM »
911's seem much different.... Or in Geoffs first post
« Last Edit: September 10, 2016, 09:51:14 PM by bwaz »
Re: Engine codes
« Reply #8 on: September 10, 2016, 10:20:50 PM »
Sounds like a 73 beetle motor: http://www.thesamba.com/vw/archives/info/bugchassisdating.php , is it 6 cylinder, or 4?
Offline bugbuzz
Re: Engine codes
« Reply #9 on: September 11, 2016, 09:16:58 AM »
It's a 4... And clearly a vw engine. Lots of crome on it is all.
Car has front disc brakes and is in vary good shape. Not sure what it's worth but he's asking 3900?
Offline tinman
  • Junior Member
Re: Engine codes
« Reply #10 on: September 14, 2016, 11:37:04 AM »
Sorry, not sure if this is the right place?  I have an old engine 1328068, year?  no prefix letters.
OOPS found it, looks like Jan,1956.
Offline hank
Re: Engine codes
« Reply #11 on: December 06, 2017, 09:23:17 AM »
I'm trying to find out about a 36hp engine with a code I've never seen before
E-21927
anybody have any idea what year
thanks
Hank
Offline hank
Re: Engine codes
« Reply #12 on: December 06, 2017, 08:16:05 PM »
I think I found out the answer to my 36hp year question
it might be a VW industrial engine made from June to July 1956
cheers
Hank
Offline 72vwtype2
  • Phil
Re: Engine codes
« Reply #13 on: December 06, 2017, 10:07:13 PM »
Another possibility is (see last comment of this Samba post)
https://www.thesamba.com/vw/forum/viewtopic.php?t=433995&highlight=engine+code
1972 Kombi
1964 Vespa 150
Offline hank
Re: Engine codes
« Reply #14 on: December 07, 2017, 08:58:23 AM »
that was an interesting thesamba posting
I bought a VW powered ski hill tag line system 30 + years ago
it had a 36 hp. engine hooked up to a type 2 split case transaxle with one brake drum bolted to a solid arm on the mount.
I'm not sure if this "E" engine was the one or not that powered it- I have a few other 36 hp. engines
thanks
Hank
