Author Topic: Floorpans and running gear  (Read 7477 times)
Offline 1991vw
  • Junior Member
« on: July 27, 2011, 01:14:52 AM »
Just wondering out of curiousity what are the differences between the pre 1970, 1971 to 72, and 1973 to 79 floorpans in the standard beetle? could you take a pre 1967 body and put on a 73-79 floorpan? Thanks
1991 volkswagen jetta turbo diesel
Looking for an aircooled Volkswagen
Re: Floorpans and running gear
« Reply #1 on: July 27, 2011, 03:05:07 PM »
The perimeter shape of all floor pans are the same.  The seat mounting is why they are different.
A 67 body will only fit a standard Beetle floor pan.  Not a Super's pan.
Offline 1991vw
  • Junior Member
« Reply #2 on: July 27, 2011, 05:11:45 PM »
so I could take a 1974 standard beetle rolling pan and put a 1967 or earlier body on but I would have to use seats out of a 1974 beetle?
« Reply #3 on: July 27, 2011, 10:59:40 PM »
That's correct.
To put the early body on a 68 or later pan, you must modify the one body mount under each rear fender.  Otherwise everything else is bolt on.
