Author Topic: Need some window regulator help!  (Read 8587 times)
Offline HaggardRob
« on: July 25, 2011, 10:38:15 PM »
I think the passenger side window regulator just went on my '64 beetle. It has brand new window seals, and it rolled up and down fine. I put new door panels on it and it became hard to roll up and down, and just on sunday when my girlfriend was rolling the window up something snapped (?!) and the crank spun freely. I took the door panel off today to check it out and the cresent shaped gear thinger was sitting at the bottom of the door not attached to anything and there was a largish washer with two pin things in it down there too. I did some searching on the samba for how to fix it without anything too helpful.
If someone has a free night sometime this week (or sometime soon)  and has some experience fixing this kind of thing I would be glad to buy you a case of beer or give you some cash for your time. I can drive to you.
Please email me: Krooked21@hotmail.com
 :D
Offline HaggardRob
Re: Need some window regulator help!
« Reply #1 on: August 04, 2011, 07:43:14 AM »
Really? no one? did I mention FREE BEER ?!?!
« Reply #2 on: August 04, 2011, 07:59:53 AM »
From my experience, it's likely a broken part that the whole unit will have to come out and be repaired (replaced) as there aren't really nuts and bolts that just come loose. This image is of a way older door, so not sure if there's similarities to yours?
Offline buggal
  • April McNicol
  • 1972 STD Beetle project
« Reply #3 on: August 04, 2011, 09:13:11 AM »
Yessir, it be busted. Sorry to say, but will have to be replaced as far as I can tell. The crescent shaped gear is usually riveted on. You may be able to, maybe, drill out where it came from and replace the rivet with a bolt with a bushing on it, but it's probably not worth the effort.
Sorry for the bad luck. I'd come over, but I live in Penticton.
Offline buggal
  • April McNicol
« Reply #4 on: August 04, 2011, 09:18:07 AM »
cip1 has a replacement for about $26 here's the link.
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D111%2D837%2D502%2DD
Offline HaggardRob
« Reply #5 on: August 04, 2011, 06:42:27 PM »
What is #44 in that picture? I think i have one of those in a box somewhere. Whats its purpose?
« Reply #6 on: August 04, 2011, 08:21:55 PM »
#44 is a bracket to provide support for the arm rest.
« Reply #7 on: August 05, 2011, 06:00:25 PM »
I think your going to have to take the regulator out, take a good look at whats gone wrong and post back. Taking it out isn't super difficult if I remember.
