Author Topic: bus swingaxel with reduction boxes WANTED!!!  (Read 2246 times)
Offline beetlemandan
« on: June 11, 2011, 06:44:05 PM »
well? anyone got one that can be stuffed into my '68 baja?
the customer is always wrong
Offline vwguy
Re: bus swingaxel with reduction boxes WANTED!!!
« Reply #1 on: June 11, 2011, 07:10:42 PM »
PM sent
Offline donagh
  • 61 bus and 59 karman cab
« Reply #2 on: June 13, 2011, 03:57:49 PM »
I have full rear end out of a 61 bus, tranny was fine and the reduction boxes were all rebuilt a few years proir to convering, I also have the brakes.  If interested call me 604-626-2233.
« Reply #3 on: June 13, 2011, 08:28:39 PM »
where are you at and what do you want?at this point, location and quality is more important to me
Offline donagh
« Reply #4 on: June 14, 2011, 03:23:19 PM »
350 for everything, tranny brakes, reduction boxes, its missing the nose cone but everything worked proir to removing, including the brakes, it came of a low miles us import so no rust. I'm in vancouver but could probably get it shipped to the interior if you could pick up at the depot in Kellowna for very little.
Its stored at my work in the warehouse, if you are interested I'll pull it down and take some pictures.
Offline kris
« Reply #5 on: June 14, 2011, 05:39:48 PM »
I am up near vernon with a split case tranny and big nut gear reduction boxes. give me a call at 250 308 7756
« Reply #6 on: June 15, 2011, 01:57:12 PM »
 will the nose cone off my 68 fit and work?
Offline donagh
« Reply #7 on: June 16, 2011, 10:45:37 AM »
Sorry, no idea if it would work with a 68, anyone?
I also have a new master cyclender that comes with the package
Offline riff raff
« Reply #8 on: June 18, 2011, 12:57:49 PM »
A nosecone off a 68 Type 1 will work on the transaxle, but it depends if the rail is set up for the Type 2 or the Type 1 nosecone.
The hockey stick comes out at a different place on the two different nosecones so it depends where the shift rod is in the rail.
« Reply #9 on: June 19, 2011, 08:17:15 PM »
its a 68 baja with the OG swingaxle. i'm going to assume that means i just replace my OG nose cone and hockey stick onto the donor bus swingaxle?
« Last Edit: June 19, 2011, 08:19:01 PM by beetlemandan »
