Author Topic: Oversize door hinge pins.  (Read 2466 times)
Offline number3
  • Rob Frose
    • http://www.avrparts.com
« on: June 06, 2011, 02:57:06 PM »
Need to put larger hinge pins on the beetle.
Hinge pins are 8.1mm diamter which seems like an odd size to get a matching drill bit for.
Any suggestions?
Re: Oversize door hinge pins.
« Reply #1 on: June 06, 2011, 03:04:32 PM »
An "O" bit is 8.0264mm, which I would bet since you're hand-drilling it will end up being right for your 8.1 bushings.
But it would appear that 8.1mm is relatively easy to obtain drill bit size.
http://www.mcmaster.com/#metalworking-and-multi-purpose-drill-bits-and-rods/=cmuom6
$6.48 at Acklands Grainger:
https://www.acklandsgrainger.com/AGIPortalWeb/WebSource/Search/globalSearch.do?{globalApp.quickSearchSearchType}=&{globalApp.quickSearchCriteria}=8.1mm+drill+bit
...I know you have an orange door in the barn you could practice on ;-)
Offline number3
  • Rob Frose
« Reply #2 on: June 06, 2011, 03:58:57 PM »
Don't you have a spare in your "Bin O Tools"?
I guess I will mic the pins first to see if they actually are 8.1mm.  The stock 8mm ones are around 7.85mm according to my crappy tire micrometer.
« Reply #3 on: June 06, 2011, 04:37:56 PM »
I think I've got 2 or 3 "O" bits, Ti coated, brand new. But no 8.1mm :P
« Reply #4 on: June 06, 2011, 06:10:58 PM »
Hinge pins require a reamer not a drill bit to make the hole larger for OS pins. Go to your local machine shop supply store, they can get what you need for the size of pin you are installing.
Offline number3
  • Rob Frose
« Reply #5 on: June 07, 2011, 02:22:45 PM »
8.1mm pins mic out at 8.15mm. :huh:
