Author Topic: Need Used Steel Spoke Rims  (Read 14013 times)
« on: August 12, 2003, 02:41:41 PM »
Im looking for some of the 15\" steel spoke rims for my baja bug. Ive just added Thing beam with 5 lug drums on it. I could also use adaptors for the rear as i have only 4 lug drums on the rear. pls E-mail me if you or any body you know has some. sgrant@tri-m.com
thx Shawn
Russ
« Reply #1 on: September 15, 2003, 12:19:57 PM »
i just pulled an ugly set (2) down from the rafters you can have them for 20 bucks if your interested.
i live in the langley area
if your interested just post on here and i'll pass along my number
russ
« Last Edit: September 15, 2003, 12:20:28 PM by R.Scott »
« Reply #2 on: September 15, 2003, 12:39:02 PM »
Yes Im Interisted . Could you pls let me know the width.Im in Maple Ridge. I could pick them up this week if possible.
cheers shawn
Russ
« Reply #3 on: September 15, 2003, 01:19:10 PM »
they look to be 15 X 5
you can call me at work 888-3712 i'm here until 4
thanks russ
Russ
« Reply #4 on: September 15, 2003, 01:31:52 PM »
i'm not real sure on how to measure them i just measured straight across which is 5\" but it might only be 4\" if i measure the inside??
call me if you want
russ
« Reply #5 on: September 15, 2003, 01:39:40 PM »
Hi Russ
Im looking for a 7\" - 9\" wide rim . I have 10.5\" wide tires to go on them.unfortunatly i dont think they will work for me.
Thank for letting me know
Cheers Shawn
Russ
« Reply #6 on: September 15, 2003, 02:12:25 PM »
not a problem
