VW Club Corner
horn trouble
Topic: horn trouble (Read 5732 times)
mrbrief
Junior Member
horn trouble
May 14, 2011, 12:31:08 PM »
well been having trouble with my horn in my buggie , goes on when ever i turn right , cant seem to figure it out , anybody out there care to lend a hand
mike
buddy boy
Marked for life
Re: horn trouble
May 14, 2011, 01:57:52 PM »
i had this problem years ago , and it ended being that something was touching/rubbing when ever i turned causing it to connect and sound the horn , a little filling and problem solved.
blue bus
Re: horn trouble
June 03, 2011, 06:56:33 AM »
I just had the same problem on my 74 bus.
The plastic ring where the steering column goes through the floor had popped up and whenever i turned the wheel the the column would ground out against the floor pan. I fixed it by cutting a piece of washing machine drain hose and wrapping it around the steering column so that the floor pan could not touch the column and it was fixed. One day i will pull the column and put a new ring on it.
Cheers
VW Club Corner
horn trouble
